Oil Pressure Drop
Old Jan 13, 2019 | 06:56 PM
Phantom309's Avatar
Phantom309 is on a distinguished road
Default Oil Pressure Drop
Howdy y'all. I'm new here and simply was curious if any of y'all have had your oil pressure guage stay above 40 when you first state up, but when it gets to Temp it drops. Not completely losing pressure, but it sticks around 20 mark. If any of y'all can help ifI appreciate it.
Old Jan 13, 2019 | 07:16 PM
Sounds normal actually, mine does about the same.
Once warm, it should raise with the RPM's as well.
Old Jan 13, 2019 | 07:33 PM
Phantom309's Avatar
The issue is that mine only remains at 20lbs ish until the motor is cold started
Old Jan 13, 2019 | 07:59 PM
Welcome. The pressure can be pretty low when the engine is warm and only idling.
Old Jan 14, 2019 | 07:43 PM
go chevy's Avatar
I also agree with Christine and Blazen Red, they know their stuff! Mine is about just the same pressure...
Old Jan 14, 2019 | 07:46 PM
go chevy's Avatar
Forgot too say welcome aboard! Phantom 309... Love the name and that was a great song
Old Jan 14, 2019 | 09:37 PM
odat's Avatar
If you have no rise in pressure as you increase RPMS your oil pressure sending unit may be getting weak,
However as blazen_red stated there is no problem with 20 lbs for pressure. It will run all day with that.
Heck in the old days when your inst. cluster just had idiot lights the oil light usually didn't flicker until pressure hit 2 or 3 lbs
Yes I'm that old
Old Jan 19, 2019 | 08:05 PM
TxTurtle's Avatar
TxTurtle is on a distinguished road
Mine did the same thing. I stressed out about it for a while after getting the balzer & then realized it was pretty much the same everytime & decided it was within operating parameters. Sending unit might be on it's way out.
RyansChevy
19
Apr 13, 2011 06:42 AM
matt92
Mar 25, 2011 09:13 AM
p90tr8
Jun 1, 2010 06:41 PM
MEHusky
Apr 27, 2008 07:19 PM
88s10Blazer
Dec 6, 2006 02:49 PM
