Oil Pressure guage fluctuating
Old Aug 29, 2020 | 04:05 PM
A1 Handyy's Avatar
A1 Handyy is on a distinguished road
Default Oil Pressure guage fluctuating
I just purchased an 04 Trailblazer with 134000 miles. The truck looks to be in excellent condition but I notice when I start the truck the Oil Guage reads like it should (around 40-60 lbs) but after a few minutes it goes to 0. The truck runs great with no major noise but there is a little valve rattle. I checked the oil level and it was about two quarts low and when I added the oil the noise subsided somewhat. I did notice however when I removed the oil cap there was a milky type of residue inside the cap. After driving for another 10 miles I looked again inside the cap and there was none after I had wiped it clean earlier. Is this an indication of major problems within the engine or is there possibly a less ominous conclusion. Thanks
Also, there is no milky substance on the oil stick only on the cap. Also, there is no evidence of oil in the radiator or reservoir and the engine temperature stays constant at 200 degrees and there is no evidence of overheating. The water reservoir remains at the same level and does not seem to be losing any coolant
Last edited by A1 Handyy; Aug 29, 2020 at 05:14 PM. Reason: Additional information
Old Aug 29, 2020 | 04:10 PM
Milky is a sign of water/antifreeze mixing with oil, and that will screw your bearings. Not sure about the trailblazers, but on the blazers, it's the lower intake manifold gasket.
Old Aug 30, 2020 | 07:36 PM
daveca's Avatar
Milky in the cap is not automatically a sign of antifreeze in the engine. My 95 S10 did that... No antifreeze in the oil. 40000 miles later at 285000 it round like new.
just a little moisture condensation in the cap ( which is cool compared to the engine internals) is enough to do that. That can be caused by a faulty PVC system or very hugh humidity.
If theres moisture in the crankcase vapors the PCV system should suck it out and run it thru the engine.
Check the PCV system first.
blazerhelp01
Feb 19, 2015 02:30 PM
punnerab
Jun 17, 2009 11:34 PM
tammikm
Nov 19, 2007 10:26 AM
mogley99
Apr 7, 2007 09:23 PM
