Overheat issue
Overheat issue
I have a 97 chevy blazer 4.3, 4 wheel drive i had an issue where my trucks temp gage startex to rise and spiking out at 260 i would immediately pull over shut off and.give it a few to.cool then start again .. But then i noticed it would spike and i pull over and put in park and hit gas a few times and.it would.drop below the half mark and i had no heat ... So ok i replaced the thermostat, still no heat, replaced the resister, nothing, replaced the blower motor and boom i got heat but now after driving a few minutes with heat on it will still spike at the 260 mark i would pull over pop in neutral hit the gas a few times and it comes down to below half put in drive and drive a few minutes like.maybe 10 if that and boom back.up to 260 im at a loss i dont know what could be the problem, theres no leaks all hoses are hot so nothing plugged clutch fan working any ideas would be appreciated.
I would also change the oil while you're at it, since those overheating cycles probably baked it. Also, you will need a 36mm wrench to remove the fan. I rented one from Auto Zone for $20. A quick YouTube search should yield several ways to remove it.
Let us know how it turns out.
Water pump. Mine did that before I replaced the water pump. There's an impeller inside thats probably worn down so that it no longer pushes coolant efficiently enough to maintain engine temp. Do yourself a favor and get an AC Delco pump. I've been through 3 of the store brand models (Carquest at Advance Auto Parts)in the last 6 months. It gets expensive replacing coolant at that rate. And be sure to use the included gaskets, use some high temp RTV, clean the mating surfaces thoroughly (I used a brass brush on a drill. Worked perfectly). And torque the bolts to the proper specs. It was 33 foot pounds on mine, but I have an 02. I'm sure it's the same for your 97, but double check to be sure. Hope this cures you.
ohsingltrakr
06-22-2020 02:05 AM
blk97blazer
02-16-2007 08:32 PM
il67bp
08-18-2005 12:26 AM
