Overheating problem
Old May 24, 2017 | 08:25 PM
nick.ainsley518@gmail.com's Avatar
nick.ainsley518@gmail.com is on a distinguished road
Default Overheating problem
I have a 2000 chevy blazer LT and it overheats while im driving but when i idle it will stop where its at. It might go down a little but thats it. Now ive done replaced water pump and thermostat. And flushed the system out. Theres no signs of a head gasket blown. Oh and i have changed the clutch fan as well. What else could make the blazer run hot slowly?
Old May 25, 2017 | 02:37 PM
run_girl's Avatar
run_girl is on a distinguished road
I had the same problem this week. I did the same replacements and it still overheated. Have you taken the radiator out and looked for any signs of damage? Or clogged on the radiator? I had a crack in mine, which caused the persistent overheating. Had I not taken the time to pull the radiator out, I would have never seen that crack. Good luck and keep us posted!
Old May 25, 2017 | 02:43 PM
Was the radiator leaking or just have a crack without a leak?
Old May 27, 2017 | 08:14 AM
abig84's Avatar
dont know if this would happen with a clutch fan but make sure the fan is blowing towards the engine. on another forum someone was having the same issue with a electric fan, was fine idling or going slow but hit the road and it would overheat. the fan was actually blowing the wrong way
Old May 27, 2017 | 09:13 AM
how woulf i know if it was put on backwards?
Smiller94
Sep 2, 2009 08:05 PM
scottvwcars
Dec 10, 2008 08:10 PM
SnowRemorse
Sep 8, 2008 10:52 PM
derek b
Mar 10, 2008 01:31 PM
ryansoxfan
Aug 28, 2007 03:45 PM
