P0751 & p1870
Old Sep 8, 2021 | 12:15 PM
Default P0751 & p1870
2000 jimmy 4 door 4x4 4.3 auto 4L60E stock
Momma's jimmy has been slipping, fluid is a little dark and has a leak.
The shop wants to drop the pan, do a transmission flush and change the trans cooler line. Quoting 500$
My question before allowing this, what are the chances of this solving the problem, or am I looking more towards a rebuild?
Or can I get away with the solenoid A, and fixing the leak?
I'm going to pick it up sometime this week, will be able to get a visual on where the leak is coming from. The shop toped off the fluid and charged for a diagnostic for 100.
Old Sep 8, 2021 | 08:47 PM
Doing more slow research, and found these.
Has anyone had to deal with these? and am I just prolonging a trans rebuild?
It does shift a little better now that they CHANGED the fluid, yes all the fluid. But it still does NOT go into second without a manual shift.
Old Sep 10, 2021 | 10:46 AM
Transman304's Avatar
Unlikely the fresh fluid and solenoid will solve the problems you describe. Will the transmission shift past second gear after manual shift?
Brad
Old Sep 10, 2021 | 11:53 AM
Yes sir. I got no problem after it's into 3rd.
But now unfortunately lost 2nd all together... Does not go into 2nd manually
Old Sep 13, 2021 | 01:16 PM
Could be the band servo has cut seals. Second and fourth use the band to achieve these gears.
Old Sep 13, 2021 | 01:47 PM
Thank you!
I had suspicions that the transmission would need to be opened up more then just the pan and flush. Although it's hard to say if this is the problem, it is better then waisting 500$ just to replace the unit the next day..
Thanks again
just trying
Feb 23, 2021 08:54 AM
dharvey4651
Apr 3, 2015 05:30 PM
ComputerNerdBD
Dec 5, 2014 05:17 AM
spazblazer
Nov 27, 2014 02:58 PM
