P1133 Code
Old Feb 22, 2014 | 07:28 PM
  #41
The pump should run for ~2-3 seconds when you turn the ignition to off, perfectly normal. Keep us posted on how it goes.
Old Mar 5, 2014 | 05:37 PM
  #42
Tenagator's Avatar
Tenagator is on a distinguished road
Well since my last post I filled the tank.
Currently its at 1/4 left and I have 155 miles on it.
This is with very few morning warm ups sine it has not been to cold.
I figure I should have roughly 4.75 gallons left. I doubt I will make it to 180 miles. I know its not right ,lets figure I hit 180 that's ALMOST 9.5 miles per gallon, definitely not good.
So, what's the next step to figure out my poor mileage? The fuel pressure is good, everything is working fine now.
I have the old 02 in there, I have a brand new Denso one.
No codes at all, but I was getting the codes with that Denso I had in there, I believe the heater wasn't working.
So, what other ideas should I try now?
Thanks
Old Mar 7, 2014 | 06:09 PM
  #43
Tenagator's Avatar
Update.
Today I hit 180 miles , the fuel gauge was in the red.
I filled up, it took 14 gallons....meaning I had 5 left in the tank, so is my gauge or sending unit off? should it be in the red on empty with 5 gallons left?
I figure since last fill up I was able to get 12.85 miles to the gallon, but still had 5 gallons left so if I drove till empty I would get roughly 240-245 miles on a full tank.
So I really think the gauge or sending unit is messed up.
What sounds reasonable?
Old Mar 7, 2014 | 09:33 PM
  #44
The tank is not symetrical so the gauge is not accurate at all fuel levels. Fuel gauges in these vehicles are more of a "suggestion" of how much fuel is in the tank, not gospel by any means The most accurate way to check fuel mileage is to fill the tank. Then use a GPS to track mileage. Fill the tank again. Mileage travelled divided by fuel used = MPG.
Old Jun 13, 2014 | 04:09 PM
  #45
SoullessNihilist's Avatar
SoullessNihilist is on a distinguished road
Default P1133
so P1133 could be caused by a exhaust leak? like manifold to Y pipe not sealed?
Old Jun 13, 2014 | 08:42 PM
  #46
Yes. Here is the diagnostic flow chart for P1133. Scroll down to "DIAGNOSTIC AIDS" for possible causes.
https://blazerforum.com/forum/diagno...plained-30095/
Foxcliffe
Jun 18, 2013 12:36 PM
Little Roober
Dec 17, 2012 03:34 AM
jukeboxhorse
Apr 29, 2009 11:28 AM
BlazerLove
Jan 21, 2009 07:19 AM
