P1345 but runs well
Old Apr 22, 2023 | 08:24 PM
Annodekim's Avatar
Annodekim is on a distinguished road
Default P1345 but runs well
I just purchased a 2002 blazer and the SES light is on with a P1345 code. The engine runs just fine though. I don't want to pull the distributor unless I have to. Can it run well and still be one tooth out of time?
Old Apr 22, 2023 | 08:42 PM
LesMyer's Avatar
You have to pull the distributor
Old Apr 22, 2023 | 11:34 PM
Annodekim's Avatar
Thanks Les. I see you went to a bunch of trouble explaining it to the last person who had the issue. So I'll expect to get a P0300 code next lol
Old Apr 24, 2023 | 04:36 PM
LesMyer's Avatar
Unless the cam position sensor itself is bad (I have personally never heard of one failing), you have to pull the distributor to fix a P1345. Worn gear or on the wrong tooth - either way distributor comes out. The cam sensor is plugged into the wiring harness, correct? They have been left disconnected before.
Old May 23, 2023 | 06:04 AM
JennyJenM's Avatar
JennyJenM is on a distinguished road
im experiencing this issue with the new distributor i put in. some are saying that the lower gear was installed backwards and needs to be taken off and reset correctly. i will try this and see if this corrects the problem
99BlazerAlex
Mar 8, 2019 05:09 PM
Matt Evan Cinquini
Feb 6, 2019 10:20 AM
Nutty 99 Blazer
Sep 11, 2017 01:45 PM
weekender
Feb 18, 2011 08:42 AM
tim68
Feb 7, 2011 07:00 PM
