p1870 code
1999 Chevy Blazer 4.3:
Man, after fixing the P0753 code by changing the shift solenoids, and changing the trans fluid and filter, I get a P1870 code. It happened 30 minutes after driving it to set the monitors, I did feel it shift hard a couple of times from 1 to 2, but after that it shifts fine. The code didn't set until I was on the freeway, but it seems to be shifting fine, so I don't know what to think.
Here's what I did before that code set: I drove the car for a while before pulling over to check the trans fluid. I checked the trans fluid while in idle, and it was low even though I had put in 5 qts., so I bought some Lucas trans fix and added that in for extra protection. Now, the levels read a bit over, so my question is, could having the trans fluid levels a bit over cause this code? Could the Lucas trans fix have caused this?
knightryderx2
Feb 27, 2010 12:10 PM
