Pistons Kit for 1998 Blazer
Old 11-22-2023, 07:27 AM
LesMyer's Avatar
LesMyer will become famous soon enough
Good luck and best wishes for a successful repair!
  #22
Old 11-23-2023, 01:28 AM
Ravfed's Avatar
Ravfed is on a distinguished road
Old 11-23-2023, 02:18 PM
LesMyer's Avatar
Silv-O-Lite ReMan Pro Piston - Chevrolet 262ci/4.3L (V6)
  • 3.160” diameter recess .080” deep.
  • 4 valve reliefs.
  • Use 1986 & earlier (5/64, 5/64, 3/16) rings.
You may need to use only 6 cylinders of an 8 cylinder ring set like these if you can't find a 6 cylinder ring set in 0.080 over. That might be difficult to find because of the oversize. Price probably isn't much different.
https://www.summitracing.com/parts/hsn-2m139080
  #24
Old 12-14-2023, 10:03 AM
Ravfed's Avatar
Hello, finally my mechanic does not want to take the responsibility of boring up to 0.080 as the cylinder's wall would become too thin so I have to accept it.
Unfortunately I can't find an engine in good conditions here in Italy and I'm running out of solutions.
Anyone has a suggestion on where to buy a used or reman engine here in Europe?
Thanks in advance for your help.
  #25
Old 12-14-2023, 12:07 PM
LesMyer's Avatar
https://atkvege.com/wp-content/uploa...engine2016.pdf
This would work. You would have to pay the core charge and not return it
Sean Stultz
09-11-2017 10:43 AM
BIG A
03-31-2017 06:23 AM
jenn_in_edmonton
12-07-2010 10:54 PM
fuganator
06-02-2009 09:35 PM
9t8blazer
03-29-2009 10:34 PM
Quick Reply: Pistons Kit for 1998 Blazer
