Power question
Old Aug 7, 2017 | 07:19 PM
SeabeeCM1's Avatar
SeabeeCM1 is on a distinguished road
Default Power question
Ok 1994 cpi I have completed tune up , temp sensor , cpi unit , air and fuel filter , removed cat , timing checked and still this engine is a dog my tbi 4.3 is faster than this any suggestions
Old Aug 8, 2017 | 01:15 AM
SeabeeCM1's Avatar
Anyone before I sell this pos
Old Aug 8, 2017 | 05:18 AM
What are the symptoms and difference to your TBI?
Starting?
Idle cold?
Idle warm?
Acceleration from standstill?
Acceleration from (let's say) 2'000 rpm?
Just need a bit more details...
Old Aug 8, 2017 | 08:18 AM
SeabeeCM1's Avatar
Starts good , rough idle cold and hot , somewhat good acceleration, no top end acceleration because trans does not kick down it also hesitates going down road I am starting to think the trans is going bad no codes 150,000 miles
Old Aug 9, 2017 | 02:18 AM
have you pulled the spark plugs?
and checked the timing with a timing lamp?
(disconnect brown wire below pax side carpet should be a connector in the 1994 s10 blazer)
Timing should then be 0.
Old Aug 9, 2017 | 04:10 AM
SeabeeCM1's Avatar
All plugs are brown timing is on 0 I took fuel pressures 50psi running are just key on with a very slow drop.Ran some techron through system seemed to a little better hesitates when cruising down the road at normal speeds
Old Aug 9, 2017 | 12:18 PM
Strangerock's Avatar
Strangerock is on a distinguished road
I could be wrong but I'm sure I've read that the CPI system needs 55 psi just to open the poppet valves properly.
Old Aug 10, 2017 | 02:10 AM
I'll have a look at the manual but it will take a day or two to have the time to do so.
flipzat
Dec 2, 2009 04:05 PM
fresno99
Jul 31, 2009 08:12 PM
1991whiteoutblazer
Jan 8, 2009 08:17 PM
nate2003456
Jan 18, 2007 01:10 AM
freeman
Aug 23, 2005 10:55 PM
