Priming oil Pump
If it's a fresh rebuild its certainly a good idea... I used a GM oil pump priming tool similar to the one below and my dewalt variable speed drill. It drops in place of the distributor and connects to the pump drive shaft so you can spin the pump once you have it all together / full of oil, etc.
FYI most parts houses will have them to buy or rent.
We used to just use and old distributor and hook a drill onto the shaft. Also you can just crank the engine over with the ignition coil wire off so the engine does not fire. You just need a good strong battery and maybe a jump starter this way. Not the best way but it does prime the pump and get the oil where it needs to go. Oh yeah i forgot. the old distributor needs to have the cam gear removed or it wont turn.
Thanks for all the tips I found the priming tool and primed it with drill. The engine is running firing great my last concern is I have uneven oil coming through the push rods. There pretty even except one pushrod is spraying it past the fender…is the oil gallery plugged. I used the old push rods on the new heads should I have replaced them?
tiso_us
14
Jan 21, 2009 02:03 PM
