Priming oil Pump
Old Nov 23, 2014 | 10:01 PM
gtmccormick's Avatar
gtmccormick is on a distinguished road
Default Priming oil Pump
do you have to prime the oil pump after an engine swap? If so how?
Old Nov 24, 2014 | 06:53 PM
KM346's Avatar
KM346 will become famous soon enough
If it's a fresh rebuild its certainly a good idea... I used a GM oil pump priming tool similar to the one below and my dewalt variable speed drill. It drops in place of the distributor and connects to the pump drive shaft so you can spin the pump once you have it all together / full of oil, etc.
FYI most parts houses will have them to buy or rent.
Old Nov 25, 2014 | 05:15 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
We used to just use and old distributor and hook a drill onto the shaft. Also you can just crank the engine over with the ignition coil wire off so the engine does not fire. You just need a good strong battery and maybe a jump starter this way. Not the best way but it does prime the pump and get the oil where it needs to go. Oh yeah i forgot. the old distributor needs to have the cam gear removed or it wont turn.
Old Nov 25, 2014 | 07:21 PM
odat's Avatar
ditto on the old distributor - it also works well for lineing up the oil pump shaft for distributor install
Old Nov 25, 2014 | 09:55 PM
Thanks for all the tips I found the priming tool and primed it with drill. The engine is running firing great my last concern is I have uneven oil coming through the push rods. There pretty even except one pushrod is spraying it past the fender…is the oil gallery plugged. I used the old push rods on the new heads should I have replaced them?
Old Nov 25, 2014 | 11:19 PM
odat's Avatar
they are not going to spray even - not even with a fresh rebuild - if the valves are set put the valve covers on - quit over thinking and worryin about it and enjoy it
Old Nov 25, 2014 | 11:35 PM
Lol love you answer hard not to worry basically rebuilt it from the ground up but will take your advice and go for a drive
1sttimejimmyowner
Aug 14, 2013 08:34 AM
chris015
Jun 8, 2012 12:37 PM
blrob5
Apr 27, 2010 03:13 PM
Brian_D
Apr 17, 2010 07:04 PM
tiso_us
14
Jan 21, 2009 02:03 PM
