Problem with fill up
Old Feb 13, 2009 | 10:17 PM
NVANZEE's Avatar
Default RE: Problem with fill up
this is the way GM designed the gauge to work. I recently posted why they did this but to make a long story short it is normal for it to be on E after around 14-15gal.
Old Feb 14, 2009 | 08:54 AM
BlazinMike89's Avatar
BlazinMike89 is an unknown quantity at this point
im guessing so the pump assembly doesnt run bone dry and suck up sediment
Old Feb 14, 2009 | 08:55 AM
88blackzcand95blazer's Avatar
88blackzcand95blazer is an unknown quantity at this point
also stop filling up after the first click
forcing more gas in the tank pushes gas and gas vapor up the evaporation lines into the charcoal canister which can ruin it and your evaporation control purge sending unit ....$
don't ask me how i know! lol!
Old Feb 14, 2009 | 08:57 AM
ORIGINAL: BlazinMike89
and so you average joe doesn't run out of gas
Old Feb 14, 2009 | 09:43 AM
LOLOL hahah yea i see. Thanks
Old Feb 14, 2009 | 10:25 AM
papacope's Avatar
ORIGINAL: 88blackzcand95blazer
that would be me. my fuel guage whent out about a year ago and haven't done anything about it, so i estimate my fuel by how many miles i've gone. since winer came around, so did donuts and drifting and less miles on a tank. so i've run my truck dry like 4 or 5 times this winter, once on my way to school, 30 miles away.
my truck usually takes right around 18 gallons when it's on fumes
Old Feb 14, 2009 | 02:47 PM
I beleive the sending unit is a part of the pump, not entirely sure though. I had mine replaced in apil 08, i cant run my car without knowing my tank level. I really would hate to run out gas in the freezing cold or anywhere for that matter. lolol, i try to keep my tank from going below 1/4 or so. keep my fuel pump submerged.
Old Oct 18, 2009 | 01:17 AM
814_fye's Avatar
814_fye is on a distinguished road
the 4 doors are 18 gallon i think the 2 doors are 16 i know they dont use same tank,pump etc.s10's have always had problems with fuel gauge the 94 and older with the 20 gal tank usually run out of gas goin up hill with 2.5 gallons left in the tank 6 of the 94 and older and they were all that way my 99 4 door has 18 gallon and you are not suposed to fill past stop because the EVAP system can't work properly
Old Oct 18, 2009 | 12:55 PM
rastoma's Avatar
rastoma is on a distinguished road
Originally Posted by Leeann_Bravada
You can download one thanks to Chevy.
http://www.gm.com/gmownercenter/
And sign up. You'll be able to download the manual as a PDF once you're confirmed.
Is there a year limit on the manual?
I just signed up with my 93 S-Blazer and I see no links or info about an owners manual.
Old Oct 18, 2009 | 03:39 PM
Stitch17's Avatar
Stitch17 is on a distinguished road
To fix the inaccurate gas gauge, replaced the fuel leveling sensor. We get trucks in all the time for this at work. What happens is the tabs that run along the variable resistor break off so they only touch sometimes. Giving you the inaccurate reading. Mine was broken when i bought the truck, when i put my new tank in i put a new sensor in and blamo she works like a charm.
jsmz
Jan 25, 2010 11:30 AM
mikegav
Nov 3, 2009 11:21 AM
dgastone
Sep 29, 2008 12:00 PM
dgastone
Sep 29, 2008 10:17 AM
filstoy
Apr 16, 2007 10:25 PM
