Question about my mechanic installing reman GM engine
Old Jun 25, 2020 | 10:03 AM
Xander12's Avatar
Xander12 is on a distinguished road
Default Question about my mechanic installing reman GM engine
Hey everyone,
So my old engine blew. My mechanic put in a reman GM engine, but he used the old radiator with the oil cooler in it. I’m reading a lot of stuff that says the old oil cooler needs to be replaced or metal shavings will destroy the new engine. Whats worse, I had a new radiator in the trunk that I told him to use and he forgot to use it. He’s going to put the new rad in for free, but do you think the new engine will be okay?
Old Jun 25, 2020 | 10:35 AM
Transman304's Avatar
Do you know exactly what failed in the motor before replacement? If it was a rod knock or low oil pressure or something along those lines I would say you should be alright. Now if it was a broken connector rod or broken piston, any type of catastrophic failure that makes huge amounts of debris I would question the reuse of the radiator. You may want to replace the radiator and remove oil filter and cut it open to view what was collected to take any doubts away.
Brad
Old Jun 25, 2020 | 11:43 AM
Xander12's Avatar
Brad
It was rod knock. He is going to replace the radiator for free, but I have already driven 100 miles with the new engine and old radiator. So I feel like the damage is already done if there were metal shavings. IDK
Old Jun 25, 2020 | 07:40 PM
The filter would catch most if not all debris. Rod knock as a failure usually does not produce the debris that would be critical. Changing our radiator is a great idea. Good luck
Brad
Old Jun 26, 2020 | 05:51 PM
Xander12's Avatar
Brad
Thank you, I really hope you are right. I’m losing too much sleep over this lol. Anyone else have any thoughts?
Old Jun 26, 2020 | 08:28 PM
I would say do a fluid change and new rad. Then you will be golden if you are not sure. I'm replacing the entire system myself with my engine as I had a bearing go.
Edit: sorry.... "if you have the money to throw at it" some will say... but I'm a "better safe then sorry" kind of person...
Xander12
May 25, 2020 09:56 PM
RexCastle
Nov 16, 2012 07:32 AM
terry s
32
Jan 28, 2012 06:35 PM
PseudoKirby
Jun 26, 2011 12:09 AM
93blazerman
Engine & Internal
Apr 7, 2005 02:26 PM
