question with starting
Old Sep 13, 2007 | 10:49 PM
Coryzblazer's Avatar
Coryzblazer is an unknown quantity at this point
Default question with starting
For the last month every once in a while when trying to start my blazer itsbattery will die and i will have to move the wires at the battery to fix the problem.I have cleaned, and tightened the connectionsand still the same problems.Anybody know what it might be?
Peace!
Cory
Old Sep 14, 2007 | 06:35 AM
Zed's Avatar
Zed
Zed is an unknown quantity at this point
Default RE: question with starting
It could be a loose ground cable
It could be a loose power cable where it attaches to the starter
It could be the battery itself as the connectors inside the battery come loose even though the cable nut(s) feel tight ..
Old Sep 17, 2007 | 02:48 AM
aris_unlimited's Avatar
aris_unlimited is an unknown quantity at this point
It could also need new battery cables.
Old Sep 17, 2007 | 10:49 PM
94blazer4.3ho's Avatar
94blazer4.3ho is an unknown quantity at this point
Check volts at battery when running, and off. Like they said, could be the battery (14.5 volts) running (12.5 volts) off
cgrett
Nov 15, 2010 09:08 PM
88skisupreme
Feb 16, 2010 08:53 PM
Sprocket
Mar 20, 2008 09:39 PM
HaRt
Jun 12, 2005 04:15 PM
Im_Bryan
Mar 29, 2005 01:20 PM
