Really need help!! 2001 Blazer cranks but won't start
Old Jul 25, 2008 | 12:51 AM
sindy1232's Avatar
sindy1232 is an unknown quantity at this point
Default Really need help!! 2001 Blazer cranks but won't start
Several weeks ago I was using a pump for a raft, connected thru the cigarette lighter, and the car battery went dead. Got a jump and all was fine.
Couple of weeks later, drove the truck as usual and when I got out of a store it would try to start but would not fire over and start. We got a new battery to try becuase the battery gague was really low but this did nothing. Had the truck towed home and when it was off loaded from the tow truck we tired to start the Blazer and it started just fine! Noticed that the battery cables were pretty dirty so we cleaned them and had no problems until tonight.
My son took the truck to the store and once again it will try to start but just will not turn over and the battery gague is really low again! We tried to jump it but this did nothing at all. I am clueless as to what could possibly be wrong!
Does anyone have any suggestions as I really can not afford to take it to the shop.
I love my truck and have very little problems with it but right now I am just totally stuck!!
Old Jul 25, 2008 | 09:53 AM
raylo's Avatar
raylo is an unknown quantity at this point
Default RE: Really need help!! 2001 Blazer cranks but won't start
Probably failed or weak fuel pump.
Old Jul 25, 2008 | 11:41 AM
El_Beautor's Avatar
If you're alreadyhaving problems with corroded battery cables and terminals, try replacing those first.The corrosion can go deeper than the surface, and prevent a proper connection, and this can be affected by the vibrations of driving, thus the intermittant problem.
Old Jul 25, 2008 | 11:59 AM
WolfPack's Avatar
I would try removing the battery, take out the battery tray, and inspect the cables all the way down. Also consider getting your alt. tested (autozone and advance test for free)
robwatson
May 22, 2013 05:40 PM
Rhodes19
48
Feb 15, 2013 09:46 PM
bsbob
Jul 22, 2011 12:48 PM
nyjeepman
34
Mar 15, 2009 07:40 PM
jdbrown66
Nov 19, 2008 03:57 PM
