Rebuilding my tranny in my 2wd '01 Blazer
Old Jan 22, 2019 | 12:18 AM
TxTurtle's Avatar
TxTurtle is on a distinguished road
Is this a good deal? 4L60 tools on Ebay $120 bucks for a set of tools for this Mostly interested in the drum puller & the clutch compressor. Those alone are nearly this price on Amazon
Old Jan 22, 2019 | 07:34 AM
Transman304's Avatar
Yes that’s a good deal but you really only need the low/rev spring compressor. Pump puller is not needed, ring sizers would be nice but also not needed. For a one time rebuild or a few DIY builds in my opinion not needed. Spend the money on parts that will increase the longevity of the build. Also a side note, don’t shop for parts by lowest price. You will absolutely get what you pay for. Lot of aftermarket peddlers out there selling china parts as Direct replacement or even OEM. I will be working on the list for you today of parts. Also would like to start on a step by step tutorial or even a video if there is interest from members and time allows.
Brad
Maybe look into this for the compressor. It looks like it will do low/rev and rev input drum. I have never used a tool like this so can’t say how it performs.
Amazon Amazon
Old Jan 23, 2019 | 06:27 AM
I am sharing my preferences for parts for a 4L60E that I use and continue to use in my overhauls. Every builder has his own recipe for parts that give them the desired results. I don’t do patch jobs or very basic overhauls by putting in new clutches and band and call it good.
The brands I list are what I have good success with and not saying you must use brand A and not brand B . This is what I use your results may differ.
First is a good converter. I have a local converter shop that I use exclusively. Top Line Converter in Pittsburgh PA. 412-464-9985.
In the past have used with success converters from.
Precision of New Hampton.
Florida torque converter.
Bushing kit
Corvette servo
Borg Warner High Energy band
Transtec overhaul kit
Borg Warner frictions with the High Energy 3-4 frictions
Transgo “SK4L60E” shift kit
Transgo aluminum accumulator pistons in forward accumulator and 1-2 accumulator.
Delco separator plate
Sonnax 3-4 return springs
Filtran filter
Molded piston kit
Borg Warner Input sprag
Borg Warner Low/rev sprag
Borg Warner EPC solenoid
Delco shift solenoids
Sonnax boost valve
Delco reaction shell
This is the standard list for every 4L60E. There will be other parts that need replaced that you will find upon tear down. A lot has to do with application and what the transmission is required to do as to what areas need to be addressed . Steels and pressure plates need to be checked and replaced as needed. The pump and valve body have common bores that wear and need reamed and sleeved. Not for the DIY builder as the equipment and tooling is quite expensive to perform these repairs. The shift kit addresses the main wear area with re designed valving . Another area is the rotor,vanes,slide and pivot pin that wear. Planetary pinion bearings and shims will wear. Planets can be rebuilt and the captured Torrington bearing replaced. But again specialized tooling required to press apart.
Please ask any questions or mention any parts that weren’t listed.
I will work on a list of tips and techniques to help avoid problems with the overhaul.
Brad
[img]blob:https://blazerforum.com/e0b0773a-ad9...5-16e9abeebf08
Old Jan 25, 2019 | 06:18 PM
TxTurtle's Avatar
Thank you!
peenar
14
Feb 23, 2019 04:11 PM
press1280
24
Feb 5, 2018 03:05 PM
Patton
Apr 10, 2013 09:24 PM
Ugly_Monkey
Feb 4, 2009 08:58 PM
lachrimae
Dec 6, 2006 02:54 AM
