removing the front drive shaft on Bravada
Old May 18, 2015 | 11:22 AM
packrat's Avatar
packrat is on a distinguished road
Default removing the front drive shaft on Bravada
I have a 94 Bravada just a putt around truck back and for the to work and short runs no family road trips, well just got the news that the front differential is messed up thinking of unhooking the front drive shaft and just leaving it be 2wd ?
Old May 18, 2015 | 06:36 PM
Your truck is equipped with BW4472 transfer case that splits the torque between the front and rear axle, 35%/65%. It is a fluid coupling transfer case which has no physical connection between the transfer case input shaft and the rear output shaft. As such, there is no 2wd mode. If you disconnect the front driveshaft, you will burn up the transfer case and likely go no where in the process.
Old May 30, 2015 | 08:58 PM
packrat's Avatar
Default removing the transfer case
OK thanks for the info, can I remove the transfer case and put a 2wd tail shaft on the transmission ?
Old May 30, 2015 | 09:18 PM
You can, but changing out the tailshaft on the 4L60E requires gutting the transmission. The tailshaft comes out through the front of the transmission case.
Razmear
14
Feb 10, 2018 01:06 PM
Chevy33
Jan 20, 2011 12:03 AM
street101
Oct 29, 2010 04:17 AM
drodr05
Sep 24, 2010 02:15 PM
lizzj70
Jun 23, 2010 06:57 PM
