Replace or rebuild
Old Mar 12, 2021 | 05:38 PM
VotiveFire's Avatar
VotiveFire is on a distinguished road
Default Replace or rebuild
I have 188k miles on my 92 blazer. Its the original engine and it's a daily drive for me. It's just now started leaking oil and sometimes has a "ticking" noise from the rocker arms(maybe). I had an earlier post about this, but it might be coming down to the wire. Should I go ahead and replace the engine with a newer one or do a rebuild on the original?
Old Mar 12, 2021 | 05:42 PM
LesMyer's Avatar
Probably should evaluate the cause of the ticking and possibly fix it. Rebuilding engine on a 1992 is a bit cost prohibitive if you need to have it done for you. ....... unless it is something very special to you.
Old Mar 12, 2021 | 05:56 PM
The good news is that Goodwrench TBI 5.7 long blocks are pretty reasonably priced, Much cheaper, in fact, than what you would pay to do a proper rebuild yourself. And they come with a really nice warranty.
Old Mar 12, 2021 | 06:18 PM
VotiveFire's Avatar
I already priced some, but my friend said i should put a newer engine in it. Something more fuel efficient, hahaha. I feel I wouldn't be doing my blazer justice if I put a newer engine in it.
Old Mar 12, 2021 | 06:19 PM
VotiveFire's Avatar
Btw, I won't be doing the rebuild myself or replacing it. That is for somone with way more experience then me.
Old Mar 12, 2021 | 06:25 PM
As far as engine replacements go, it doesn't get much easier than that one. But you still need to have some tools and some knowledge.
You can put a newer engine (like an LS) in it, but you're looking at a lot more work and expense.
Old Mar 12, 2021 | 10:30 PM
LesMyer's Avatar
And I did not catch that it was a big Blazer (not S10). Look in good shape. Should be worth fixing, one way or another.
VotiveFire
Oct 3, 2020 01:57 PM
4.3vortec
May 14, 2014 11:17 AM
offroadsandimports
Feb 27, 2014 11:46 AM
AlaskanK5
Jan 13, 2010 07:05 AM
MM01Blazer
Apr 9, 2009 11:13 AM
