Replaced distributor ran good for 30 min then shut off
I replaced the distributor on 2002 s10 blazer 4x4 4.3 and it ran fine for 30 min then it shut off again and wont crank. Could the distributor be slightly off timing? Or idk?
Distributor would not affect the engine cranking with the starter. If this isn't what you mean, then you need to re-state your issue. Do you mean that it will crank but won't start? If this is the case, does it have spark at the coil wire? Was the SES light on after you replaced the distributor and it was running for that 30 minutes? If so, what code was set?
recian
09-19-2011 07:56 PM
kgkern01
06-16-2011 10:24 PM
luca1587
01-20-2011 08:41 AM
Nutty 99 Blazer
04-02-2010 08:50 AM
phantom
02-20-2008 11:20 PM
