Water Flow Through the Heater Core
Old Jan 11, 2011 | 10:27 AM
SSTBDriver's Avatar
SSTBDriver is on a distinguished road
Default Water Flow Through the Heater Core
Can anyone tell me what is the water flow direction, through a heater core, on a '95 S-10? The inboard (top) hose goes to the water pump and the outboard (btm) hose goes to the front part of the intake. I'm not sure if the water pushes or pulls water through the heater core. Thank, Rich
Old Jan 11, 2011 | 10:52 AM
billbobagns's Avatar
billbobagns is on a distinguished road
The short answer is "it does not matter" since this is a sealed "closed loop system", a restriction at any point will slow or stop flow and reduce or kill the heating system.
The longer answer is that the water pump on a Chevy has one inlet (lower radiator hose) and several outputs (casting to block - and heater hose). So, the water flows from the pump thru the host to the heater core then returns, either to the intake or the the radiator passenger side (depending on model).
Old Jan 13, 2011 | 06:18 AM
SSTBDriver's Avatar
Thanks. From what you mentioned, closed loop system and several outputs, makes me think the supply (or pressure side) would be the heater hose coming off the top of the water pump. Thanks again.
Brian_D
Jan 11, 2015 01:25 AM
95LS
Mar 31, 2014 10:51 PM
RANDO
Mar 13, 2013 09:54 PM
97CountryJukeboxLt
Jun 26, 2012 09:17 PM
99Legendary
Apr 24, 2012 09:02 AM
