Replaced my heater core, now transmission wont shift
Old Apr 15, 2013 | 02:40 PM
slcblazer's Avatar
slcblazer is on a distinguished road
Default Replaced my heater core, now transmission wont shift
I replaced my heater core and put everything back the way I pulled it off. Hooked everything back up. Now not only is my dash cluster, headlights, and rear hatch release button all not working. When I shift it into drive (what I think is drive) it doesnt want to shift up...
Any ideas???
Old Apr 15, 2013 | 06:52 PM
Twip's Avatar
sounds like your shift linkage might need some adjustment. everything else sounds like it might be a fuse.
Old Apr 15, 2013 | 07:24 PM
warthogdriver's Avatar
Did you disconnect anything on your body control module behind the ashtray?
Old Apr 15, 2013 | 07:40 PM
slcblazer's Avatar
Yeah I had to disconnect the whole unit to get the core housing out.
I literally went through EVERY SINGLE fuse in BOTH boxes and it still wont work.
Old Apr 17, 2013 | 12:50 PM
slcblazer's Avatar
Took to mechanic, he has no idea whats wrong with it... any ideas???
Old Apr 19, 2013 | 12:31 PM
slcblazer's Avatar
Finally got it fixed, turns out that when I was reinstalling the dashboard assembly and plugging the main plugs that bolt together I bent a pin and thats what caused the issue. Will NEVER do a heatercore job again lol
RANDO
Mar 13, 2013 09:54 PM
grounded87
Jun 29, 2011 09:12 PM
Steinbruchsoldat
Mar 23, 2011 04:37 PM
mcatnova
May 17, 2010 06:27 AM
LemonBlazer
Jun 22, 2009 02:53 PM
