Replacement radiator, nozzles wrong
Old Jan 18, 2010 | 10:03 AM
ednasgoldfishuk's Avatar
ednasgoldfishuk is on a distinguished road
Hi, im a bit of a novice when it comes to car work, I recently had a problem with my radiator, mainly the plastic nozzle is cracked, anyway the garage here in Munich wanted alot of money for a new rad, so I did some research found a radiator, spoke to the guy in california and made sure it was the right one, he sent it and I spoke to the garage today and they said that the nozzles on the radiator are the wrong way round? could this be because its a UK blazer? I cant imagine thats the case? and the radiator is a 3rd party one? ideas anyone?
Thanks
another thought would it also not be possible to just make the tubes longer so that they then go into the correct nozzles?
Last edited by swartlkk; Jan 18, 2010 at 11:40 AM. Reason: Combining Consecutive Posts - Please use the EDIT function to add additional information to your post if another member has yet to reply. Consecutive Posting is prohibited by the rules of the forum.
Old Jan 18, 2010 | 12:01 PM
rriddle3's Avatar
Have you actually looked at the new radiator to compare it to the original one? That would tell you whether the inlet and outlet are on the wrong sides or not. If they are, and you told the seller in California that it was for a right hand drive truck, I would say it would be his responsibility to make a refund.
Old Jan 18, 2010 | 12:32 PM
Ok I took a look they are on the other side, also spoke with someone, again me being a novice, I did alot of research making sure it was the right one, transmission cooler etc, the only thing I never thought is that the RHD use a different rad! dang, I asked the garage if they could install the hoses to cross over, he said they can try but he cant guarantee it'll work Im guessing because it will loose pressure and put more load on the pump? anyone have experience of fitting a LHD rad in a RHD?
Old Jan 19, 2010 | 01:47 PM
I spoke to the garage today and they said they couldn't find any OEM GM parts that would fit the radiator in, would it be possible just to buy some new silicon hoses and cross them over? in theory?
Thanks
Old Jan 20, 2010 | 09:40 PM
neo71665's Avatar
Are you talking about the water ports are on the wrong sides or the transmission lines?
If its the water ports sounds like you have the wrong radiator. Models with a 2.8 has the ports reversed compared the 4.3 engine.
If its just the tranny cooler lines you can easily extend them to make it work with pressure rated rubber hose.
Old Jan 21, 2010 | 04:02 PM
Well its the 4.3 V6, but turns out the RHD radiator is mirrored from the normal LHD, so had to reorder the correct RHD rad, you really dont want to know how much!
All the lines are swapped over, so I figured better to play it safe and get the real deal
Old Jan 21, 2010 | 04:28 PM
rriddle3's Avatar
Actually, yeah, some of us would like to know how much.
Old Jan 22, 2010 | 06:27 AM
Well here with shipping from US, 500 euros!! bearing in mind for most cars here I would expect to pay 100-300 (e.g. 300 being for a BMX X6) for a domestic car.
Old Jan 22, 2010 | 06:42 AM
rriddle3's Avatar
Wow.
Old Jan 22, 2010 | 06:47 AM
Yea i know! Thats the problem with a pseudo import, but I need it as I run it on LPG it puts a little more strain on the cooling, oh well at least I own a blazer!
rockp2
Apr 28, 2014 05:38 PM
94BlazerPA
13
Dec 4, 2013 07:23 PM
Joshs4x4
Nov 23, 2012 09:44 PM
alt1970
Jun 9, 2011 02:30 PM
georgbohr
17
Jan 26, 2011 01:08 PM
