Rod Knock, Engines that can swap in?
Old May 10, 2011 | 08:38 PM
PseudoKirby's Avatar
PseudoKirby is on a distinguished road
Default Rod Knock, Engines that can swap in?
as far as I can tell the 95 had a new engine with the new gen and then the following year they moved to the L35 and then the LU3 Vortec, I am just wondering what engines can go in relatively easy as far as swapping accessories and the intake manifold ect.. somehow the newer Vortec S-10 engines are actually cheaper than the 95..
Old May 12, 2011 | 01:00 AM
so is it just a 95 engine then? or could the previous generation engines work???
Old May 12, 2011 | 07:06 AM
You have to look at the timing cover bolt arrangement. The cover changed somewhere in the '94-'95 time span. You will likely need a cover that has the provision for the CKP (crank position) sensor. The '96+ SCFI engines have different bolt patterns for the intake manifold. I have heard that the blocks are very similar, but have not read of anyone that has used the newer block in an older application. You would definitely have to use the heads off your engine.
Here is an article that goes through the changes entitled Rebuilding the 262 by Doug Anderson up to '95, but doesn't have much information past that.
Klturi421
Aug 2, 2011 07:21 PM
1997 tricky1
Jan 30, 2011 01:09 PM
RandyRhoadsFan82
Oct 4, 2010 10:44 PM
ejschultz
Sep 25, 2009 04:05 PM
Tony H
Jul 17, 2009 08:16 AM
