rough idle
How do you see if an airinject check valve is bad??? and how can you check the smog pump?? Swartlkk? ty
Yes hertz20 i had exhaust coming out of the left bank. tried to take of the valve!!?? ya right it's seized. In reading other posts i found you can block them off. I put a piece a beer can and hose clamp on the tube from the exhaust manifold an put a plug in the rubber line to the smog pump. seems to be running like it used to. Funny thing i got the check valve answer a
soory my son hit the key board. but i was saying i would think if you suggest an answer it would nice to say how to check it then how to fix it.. not just a general reply even if you admin. hertz20 as soon as you said no exhaust should be comming out!! got it!! ty again
Last edited by swartlkk; Jul 19, 2011 at 01:48 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to add additional information to your post if another member yet to respond.
blazerguy22
Nov 14, 2013 11:50 PM
97BLAZE4X4
Feb 7, 2010 07:33 PM
