s10 jerking/surging
Old Dec 2, 2010 | 05:08 PM
All of those issues can be caused by a problem with the VSS (vehicle speed sensor). Whether it is just dirty or is failing or maybe there is a wiring problem between the PCM and the VSS.
Old Dec 2, 2010 | 06:43 PM
stevo's Avatar
stevo is an unknown quantity at this point
well ive replaced the vss the last time it did this with no solution
today i completely cleaned every ground i could find
and also put on my stock winter wheels
and it looks like its fixed.
could be my larger tires on my chrome wheels setting it off
Old Dec 2, 2010 | 08:34 PM
Rims shouldn't affect the VSS readings.
Old Dec 3, 2010 | 01:53 PM
stevo's Avatar
sorry i should have clarified
different sized tires will set it off correct?
the back were like 29 inches tall and the fronts were 26
Old Dec 3, 2010 | 03:56 PM
It might potentially be the cause for the ABS/brake/etc light, but it shouldn't affect the speedometer.
techboy89
15
Dec 21, 2017 04:20 PM
linegtdt52
13
Feb 27, 2012 08:23 PM
Darbylives
Mar 20, 2011 01:01 PM
gr8s10
Nov 10, 2009 06:27 PM
caddy500
Oct 2, 2009 11:23 PM
