S10 Stalls when cold
Old Apr 3, 2018 | 04:03 PM
Joe Alphin's Avatar
Joe Alphin is on a distinguished road
Default S10 Stalls when cold
I have a 1998 S10 with the 2.2 . Just recently its started running rough and almost stalls till it reaches operating temperature . After it warms up if runs fine . I seen where it might be the coolant sensor . Any help is appreciated . Thanks
Old Apr 9, 2018 | 11:55 AM
Lowered89's Avatar
Lowered89 is on a distinguished road
I currently have the same issue with an '89 S15. Had a complete tune up including a new distributor, new fuel filter, injectors, etc were cleaned, new fuel pump relay. The fuel pressure is good at 10 PSI. It does run better, but still rough and sometimes dies when put in reverse after a cold start. Did you find out what your problem was?
Old Apr 9, 2018 | 03:34 PM
Joe Alphin's Avatar
Yes i got bad gas . Several in my area having the same issue . The gas station is going to make it good . Taking to my mechanic. Just one big pain in the butt.
Old Apr 9, 2018 | 05:19 PM
Keystone40's Avatar
Keystone40 is on a distinguished road
Almost sounds like it might not be running on all cylinders - did your tuneup include new plugs and wires? Are all the wires seated/connected properly on the plugs? Are they decent quality?
Old Apr 10, 2018 | 11:25 AM
Lowered89's Avatar
Smile
I hear ya. Thank you for replying
Old Apr 10, 2018 | 11:28 AM
Lowered89's Avatar
Yes, all new plugs and wires. When that didn't fix the problem, they replaced the distributor. It's running a bit better but still not fixed. I'm working with another shop and they are going to re-check the plugs/wires. I talked to them yesterday after having it there last week..they replaced the fuel pump relay but that didn't fix problem. They think it also might be throttle body related. It also pukes out when you step on the gas.
stevenhousden
Jul 6, 2014 05:56 PM
AcerDeucerQ
Dec 29, 2012 09:30 PM
ravenhurst
15
Apr 26, 2009 07:53 AM
just a mom
24
Mar 1, 2009 06:18 PM
as2higpark
Oct 18, 2007 12:18 PM
