Scary problem
![Exclamation](https://blazerforum.com/forum/images/icons/icon4.gif)
My wife was driving her Blazer today when her throttle suddenly stuck wide open, causing her to eventually get in an accident. She drives (well, drove) a 2001 Blazer with 4WD. Anybody ever hear of something like this happening? It was a very traumatic experience for her, especially as she had 3 children in the back seat at the time.
well i doubt the cable froze if it got stuck in WOT cuz that would mean she would have to be flooring it (which i suppose is possible). But im gonna agree with the cruise control idea. But im not sure how this would happen. maybe if she had the cruise control on and a vac line fell off causing the engine to think it needed more power (i think thats how cruise control works anyways) but im not sure if a vacuum line coming off wile in cruise control would cause this.
happened to my 93 when i first got it. i was offroad at the time, had it in 4low and punched it througha mud hole. if you try to fight 4low with your muddy brakes its a losing fight. it slowed it down but i still hit a tree going like 3-4mph lol. i checked over everything and just lubed and oiled everything. best bet is to throttle the heck out of it with the truck off and look athe cable under the hood. see if its hanging up or anything is broken.
also had it happen years ago in a stick shift 83. my own fault i was messing the vacuum lines and air cleaner and when i gave it gas a vacuum T got caught in the carb linkage and got stuck
Good she' and the kids are okay!!
As to vacuum line coming loose then Cruise causing it, I dont think so. Cruise uses vacuum to pull the cable to throttle so, no vac, no pull.
Cable 'Hang', that's something else.
Dont guess you'll be troubleshooting it, tho.. if it was my wife she'd never drive it again so you might's well hope it's totalled.
