Schalter 4X4 ???
Old Oct 29, 2022 | 03:12 AM
Andy1972's Avatar
Andy1972 is on a distinguished road
Default Schalter 4X4 ???
Hallo in der Runde habe ein Blazer von 1999 ,
Das Problem : Gelbe Lampe am Schalter des 4X4 ,und Sicherung im Motorraum.
Jedes mal brennt die Sicherung durch ,unverhofft es hält dann ein bis zwei Tage ( gelbe Lampe an ) dann plötzlich Lampe wieder aus ,Sicherung wieder durch .
Bei Gelberlampe geht alles ,er Schaltet alle Gänge ,aber wnn Gelbe Lampe aus ,geht nichts.
Was kann das sein ??? Gruß Andy
Old Oct 29, 2022 | 11:31 AM
Hello in the round I have a blazer from 1999,
The problem: Yellow lamp on the 4X4 switch and fuse in the engine compartment.
Every time the fuse blows, unexpectedly it lasts for a day or two (yellow lamp on) then suddenly the lamp goes out again, the fuse blows again.
When the yellow light is on, everything works, it shifts all gears, but when the yellow light goes off, nothing works.
What could that be ???
Greetings Andy
I cannot help with this specific problem but I thought I could assist with helping others help you by posting the translation of your question. (Via Google Translate)
A couple thoughts do occur to me. First, do have and OBD codes stored that could help with the diagnosis? Second, since the fuse doesn't blow immediately, perhaps the issue is with a bad and/or intermittent electrical connection?
Hopefully another person has had this experience and can give a better suggestion.
Old Oct 29, 2022 | 08:34 PM
GeorgeLG's Avatar
Andy
Welcome to the forum. Which fuse keeps blowing, there are 4 different fuses?
George
Old Oct 31, 2022 | 06:58 PM
Andy1972's Avatar
hallo es ist immer die 20 AMP im Motorraum sicherungskasten ATC sicherung
Old Nov 1, 2022 | 12:10 AM
GeorgeLG's Avatar
This can be a few things:
A short in the wiring
A bad encoder motor assembly
A bad transfer case control module
I would start by unplugging the encoder motor assembly and use the truck for a few days and see if the fuse blows. Try to change to 4 wheel drive a few times as well.
George
bandit_60
Tires and Wheels
Mar 20, 2016 10:21 AM
tapia auto
Aug 29, 2015 11:07 AM
renoenvy08
Apr 11, 2015 11:05 PM
AlpineFox19
Oct 23, 2011 03:29 PM
markr17
Apr 22, 2009 01:47 PM
