4x4 problem - help!
Old Apr 20, 2009 | 07:21 PM
markr17's Avatar
markr17 is on a distinguished road
Default 4x4 problem - help!
I recently bought a 1994 s10 blazer tahoe 4x4..
everythign works good... except one thing..
when i start it up, and push the 4x4 button, the green light goes on and the 4x4 works.. then i will drive for a while, look down, and notice the little green 4x4 light on the dash has turned off, and the 4x4 is off.. if i try turning it on again the button doesnt ligth up and the 4x4 will not engage. But if i wait a while (this happened on 3 seperate trips) and start it up in a day or whenever, the 4x4 will go on, but eventually turn off again.
Why is it doing this? it seems to be good for the first 15 minutes of every trip and that is it.. Need some advice. O, btw, 4x4 works awesome when it is engaged. i LOVE IT
Old Apr 20, 2009 | 09:03 PM
Check out THIS POST.
Old Apr 21, 2009 | 09:43 PM
markr17's Avatar
Thanks.. helps.. but thats not exactly what mine seems to do.. It goes in on whatever setting i want, turns off after 10 mins or so, then wont turn back on. Unless i wait overnight. frusterating..
Old Apr 22, 2009 | 09:08 AM
And... Regardless of whether your symptoms match identically to those of the OP, that thread runs through the diagnostics steps. Step #1 - read the codes.
It is quite possible that your TCCM is overheating for whatever reason or that you have corrosion on a connection that is affecting things. Is it a definite 10 minutes every time?
Old Apr 22, 2009 | 01:47 PM
markr17's Avatar
um hard to say, ten mins, less sometimes. also, a lot in that troubleshooting thread you recommended me did not make sense... can someone explain it in simpler terms?? thanks
Tinted
35
Feb 7, 2011 01:12 PM
English5
Jul 16, 2010 11:11 AM
razman
Feb 22, 2009 01:57 PM
blazinloud
26
Mar 4, 2007 03:25 PM
1996blazer
Dec 6, 2006 09:34 PM
