screwdriver in sparkplug wire safe?
Old Mar 14, 2007 | 08:47 PM
scottyk's Avatar
scottyk is an unknown quantity at this point
Default screwdriver in sparkplug wire safe?
Is it safe to stick a screwdriver in the #1 sparkplug wire while cranking to check for spark?
I dont want to get blown off my feet..haha
Old Mar 14, 2007 | 09:30 PM
speeddemon560's Avatar
speeddemon560 is an unknown quantity at this point
Default RE: screwdriver in sparkplug wire safe?
I don't know if that's safe or not, but I wouldn't try that. Here's an inline spark tester. It's much safer.
Old Mar 14, 2007 | 10:06 PM
Kordog's Avatar
Kordog is an unknown quantity at this point
Yeah I have done that before, just make darn sure you have the blade of the screwdriver closer to a ground path then you have your hand!! But I would recommend using a tester though.But in a pinch it will work.
Old Apr 5, 2007 | 09:31 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Will it damage the ignition or computer to remove the plug wire at the cap and hold it about a half-inch away from the contact? That's how I've done it on older vehicles - haven't needed to diagnose on this system. Pretty easy to spot spark while cranking using that technique.
Old Apr 6, 2007 | 05:27 AM
Chevy Lover's Avatar
I haven't had any problems.....except for the time that the screwdriver slipped and the spark must have travelled into my hand and exited from my elbow which was about 1/4" from the fender....ouch!
Now I prefer to use an inline spark tester.
Old Apr 6, 2007 | 08:52 AM
drperry's Avatar
I pull spark plug wires all the time... But then again, that's on lawnmowers and tillers that the throttle cable is fubar on... A little bitty jolt and nothing major...
Probably a bit more oomph in an automotive system, lol
stark05
Jul 29, 2013 05:17 PM
rdhack
Apr 28, 2008 10:21 AM
goat6500
30
Oct 21, 2007 10:28 PM
cody32401
Nov 10, 2006 05:49 AM
Rahmir
Aug 16, 2005 12:52 PM
