Seal transmission dipsticktube
F*** I hate this vehicle.... to reach the bolt from top is not possible, from underneath the exaustpipes and lines and other stuff make it impossible. I can not even see the bolt..... I have to get an endoscope to find it. $3.00 for the part, and no way to put it in.
I see you have not yet worked on your Blazer much! There are a lot of things like this. FYI there are two other bellhousing bolts that are way more difficult to get out than this one you are speaking about. So my advice is to stop complaining and just do the repair, or pay someone to do it for you. BTW, this bolt is visible from the top on mine.
Yeah, It's not easy access, but it can be done with the distributor out and a simple combination wrench - and it's only one bolt. I don't think it is possible to get at this bolt from underneath. At least it wasn't on mine. In the future it would be helpful if you would tell us what year Blazer you are working on. I am assuming a late 1990's - early 2000's second generation Blazer in left hand drive.
And no, I can not see the bolt from top, I got a endoscope and found it. I need to reach to it from underneath, using a camara. I try to post some pictures. Hope that nobody else will have this problem.
blueblazer2002
Dec 24, 2011 08:32 PM
ANTEC900
May 7, 2011 07:17 PM
litterbug
Mar 7, 2011 09:14 PM
GMC_Jimmy_13
May 4, 2009 01:43 AM
