Sensor Pressure module
Old Nov 8, 2014 | 02:43 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Default Sensor Pressure module
The Sensor pressure module on my 02 ZR2 is loose on the top of the plenum.
This goes directly into the intake, should it be able to have so much movement up and down and be able to wiggle slightly? I would think it should be a snug fit and not be able to move. can this cause a vacum leak and trigger a Multiple Misfire code?
Old Nov 10, 2014 | 09:45 AM
rxjimmy's Avatar
rxjimmy is on a distinguished road
New red gaskets can be had for ~ 5-6 bucks delivered. A cheap enough "fix" to try. If it is real loose, yes you might get a vac leak.
Old Nov 10, 2014 | 05:23 PM
Gregg64's Avatar
Yeah it seems to move around pretty good. Im replacing / upgrading to the MPI spider this week so when I have the upper plenum off I will give it a good look see. Thanks.
JDO
Jun 29, 2010 09:34 PM
Spartan66
Jul 11, 2008 02:34 PM
blazin97
May 22, 2008 11:19 PM
hoffy
Sep 18, 2007 07:30 PM
joester
Engine & Internal
Jun 30, 2006 08:34 AM
