SES w/o code, RPM issue during acceleration
Old Sep 12, 2011 | 12:28 PM
ijustmightbecrazy's Avatar
ijustmightbecrazy is on a distinguished road
Default SES w/o code, RPM issue during acceleration
SES light is continuously on except for shortly after a disconnect of battery, but then resumes being on within a start or two. No code is being issued, had it checked multiple times at parts store. Issuing a reset from the reader has no effect.
Any time my Blazer's been sitting for a day or more, when I leave town and steadily accelerate towards 55/65, around 45-50mph the RPM will fluctuate rapidly between 2500 and 3500 until I've been steady at 55/65 for at least 5 minutes. Particularly notorious in winter, often occurs every start when it's below 35 out, regardless of whether or not it's been sitting.
Old Sep 12, 2011 | 12:32 PM
Have you checked for +12V power at pin 16 of the DLC (data link connector)? Have you tried getting it scanned with a full feature scan tool? The SES light being on means that the PCM has stored a code.
As far as the symptoms go, it sounds like your transmission is having difficulty deciding which gear to be in, 2nd or 3rd. A problem with the TPS sensor and/or circuit can cause odd shift behavior as can a dirty MAF sensor, but both should exhibit other abnormalities as well.
KrAzY
14
Aug 30, 2010 06:01 PM
mpmWS6
Jul 27, 2010 03:32 PM
bigsmitty
Oct 26, 2009 08:45 PM
Lyon
Jul 23, 2009 07:09 AM
Blazin 4x4
Oct 23, 2005 06:11 AM
