Shift problems on rebuilt trans 2000 blazer
So I just did a transmission swap to a rebuilt one but I can only start in neutral not In park, also when in D it will not shift through the gears,but i can shift between gears fine manually, will need a new shift linkage it is broken so not on correctly, says Rervese when in Park but I can shift into reverse neutral 1st, 2nd, I think it won’t go into 3rd because of shift linkage but when in D it will not shift at all, could this be the transmission I just bought? Ps: When I go Under the truck and turn manually I can go through every gear
I could shift into reverse, neutral, and drive. Nothing else. My shift cable was messed up pretty bad. If I disconnected it from the tranny I could manually hit all positions.
