so when your tranny fails...
Old Sep 17, 2011 | 10:02 PM
Carrico4's Avatar
Carrico4 is on a distinguished road
Default so when your tranny fails...
Thank you God that my transmission has failed/gone out, but i was curious, if any of you have had your tranny fail, did you just replaced it with the same trans or did you get something new and more powerful/stronger...i know the engines in our trucks are amazing an all but everyone i have talked with about the blazers and 4.3s, the first thing they ask/say is if my trans has failed or you will be replacing that soon. Thanks for any comments guys.
Old Sep 17, 2011 | 11:44 PM
chris015's Avatar
You are pretty much stuck with the 4l60. unless you put in a non electronic controlled 700r4. which is almost the same thing.
You can have them build to be stronger etc. corvette servos,better sunshells etc.
Old Sep 18, 2011 | 09:59 AM
TheRandom1's Avatar
The first time my trans went bad, I had it rebuilt using stock replacement parts.
When that failed, I had it upgraded with better clutches, etc.
Old Sep 18, 2011 | 10:03 AM
Carrico4's Avatar
thanks guys, i really hope the day doesn't come when this happens, but i am anticipating it, and wanted to know what to do to avoid it again, hopefully if, it does happen, i will have another car.
Old Sep 26, 2011 | 08:37 PM
kdcintn's Avatar
kdcintn is on a distinguished road
Default i recommend rebuilt or new
The sun shells in these transmissions are made in China and are poor quality. I, and many others, loose 2nd, 4th, and reverse when this breaks. I wouldn't get one out of a junkyard, or you could end up doing it again.
Old Sep 26, 2011 | 10:56 PM
abig84's Avatar
ive blown two transmissions in my k5 blazers. i just take them out and send them in to get rebuilt. old transmissions are dirt cheap to rebuild
Old Sep 26, 2011 | 11:39 PM
AJBert's Avatar
Just find a quality shop to rebuild it better than stock.
rpswift
May 7, 2013 10:24 PM
pettyfog
Jul 8, 2012 11:00 AM
Daytimenoo
May 14, 2012 04:42 PM
chronic1
Nov 15, 2010 10:24 AM
jman_08
Mar 21, 2010 09:40 AM
