Some kind of rattle
Some kind of rattle
Hey ya'll I have a 03 blazer 4x4 4.3 vortec that makes a little rattling sound when you accelerate but it only makes the little rattling noise between 1500 and 2600 rpms, It does not do this when it idles or if you push the gas when in park only when the blazer is in drive and you are moving, it has done this for a little while and is more irritating than anything does anyone have a sug on what it could be.
RE: Some kind of rattle
were is the rattle sound like its coming from?
When going down the road it kind of sounds like it is coming from the top of the motor in the middle if that makes any sense to you or anyone? sorry its not to specific as far as the area but I would say that about were it is coming from.
the top of the motor hhmm? can you reproduce the sound while reving it up in your driveway under the hood???
No I have tried tons of times and I can only get it to make the noise when I drive its not hurting anything that I know of but it sure does get irritating sometimes
ok hhmm?? i don't know what it could be do you think you dropped something under the hood that could be rattling maybe? im guessing without being there to hear it sorry.
I checked for that to....i don't know.......thanks for trying though and if you think of anything let me know and i'll give it a try.
Common problem. It is caused by the balance shaft. CLICK HERE for a thread on the subject showing a short explaination of what needs to be done.
In the thread linked to from the one above, the OP stated that he changed the oil to a specific brand and it 'fixed' the noise. While I doubt the problem was cured, it may have masked it. It was most likely a thicker oil that quelled the noise for the time being, but may be worth a shot.
I just got done reading those other posts and if I am going to fix it I don't want to just mask it, I am looking for something to do on my blazer anyway (I like to take things apart and put them back together like a little kid) so I think I might take a weekend and try it out, thanks for the info.
chris015
10-28-2011 09:54 PM
92K5BLAZER
02-28-2010 03:12 PM
