Some Questions About A/C
Well they only hold 2 and a half of the 12 oz cans. But even if you over filled it, that would have nothing to do with the motor not running good when the ac is off. And i disagree with the notion of not adding oil unless you have something apart. Any time you have a leak you can lose oil. In fact that is usually how you can find a leaky connection cause it will be oily. Best way to find the leak is to fill it with just straight air and get out your squirt bottle with soapy water and check everything from fittings to front seal and condenser. Unless it is the evaporator leaking you should be able to find it pretty easily. Also check the pulley bearing as well to see if it's needing replaced.
davidluzader
03-01-2010 10:25 AM
ZLover4Life
46
12-22-2008 01:01 AM
scottyk
03-19-2007 11:32 PM
