Spark plugs fouling alot
Old May 12, 2007 | 08:16 PM
fnbutch's Avatar
fnbutch is an unknown quantity at this point
Default Spark plugs fouling alot
Does anybody have any idea why all 3 spark plugs on the drivers side of my 4.3 cpi vortec engine could be caused by i checked the wires replaced the plugs yet they still foul as the other side sits and smiles. and i know that the new plugs fire so its not a coil. Thanks
Old May 12, 2007 | 08:54 PM
Default RE: Spark plugs fouling alot
I'm gonna say you have a leaking FPR (fuel pressure regulator). You'll need to verify an internal fuel leak by doing a fuel leak down test with a pressure gauge first, but I'm betting on a faulty FPR. You can also pull off the plastic cover on the top of the engine, then you should be able to unbolt a cover and have a look inside. If you see pooling fuel on the lower intake, you've got an internal fuel leak.
metalmeltr
Dec 28, 2013 08:22 AM
JJDOGG087
Feb 10, 2011 08:02 PM
1oldK5
Mar 20, 2009 10:07 PM
riverjamie
Dec 28, 2008 06:18 PM
riverjamie
Sep 18, 2007 04:58 AM
