sputter than dies
Old Sep 4, 2008 | 10:21 AM
Syder6064's Avatar
Syder6064 is an unknown quantity at this point
Default sputter than dies
I have 1993 blazer with vortec v6 4.3 w engine. It will run for a short time then it gives a sputter and dies. Normally you can just put it in nutral and it will start back up just to die
again. Sometimes though it will not restart at all. Now, when all this happens all electrical still operates normally. I've had all tests done to it, but unable to get any readings of codes. So, I figure fuel pump.So, I put new pump it ran just the same.I've been fooling with this thing since November and I'm at my wits end with it.
Old Sep 4, 2008 | 06:06 PM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Default RE: sputter than dies
with these things it could be a # of things, for me it was the IAC valve but like I said it could be a number of things
Old Sep 5, 2008 | 12:19 PM
WFD28's Avatar
WFD28 is an unknown quantity at this point
my 94 S10 Blazer did kinda what your explaining. But when it started to die if you put it in nuetral and gave it gas there was a black cloud out of the tailpipe. It was also ******* really bad when trying to accelerate.....does your truck do anything like this?
Old Sep 5, 2008 | 03:44 PM
radje00's Avatar
radje00 is an unknown quantity at this point
i have a 96 blazer 2 door zr2 that did the same thing with the black smoke and the puttering. I thought it was the throttle position sensor, it work for a min but did it again. i put a new fuel filter and a new fuel pump in it. still does the same thing. i was like f*** it i took the motor and trans out and i put a 350 vortec with a 700r4 trans and with another fuel pump that pumps 5-9psi.
foreveryoung
Jun 28, 2011 11:13 PM
W2JGA
Aug 26, 2009 06:26 PM
blazeric
23
Apr 13, 2009 08:01 AM
Poligono
Nov 3, 2008 06:01 PM
Bigblock396
Jul 18, 2007 09:49 PM
