starter or fuel pump?
Old May 30, 2008 | 02:53 PM
Psychropod's Avatar
Psychropod is an unknown quantity at this point
Default RE: starter or fuel pump?
ORIGINAL: Ralphy
thanks for the input, i'll be getting the starter checked hopefully this week.
how ever the locals here say if the fuelpump does not show 60 psi. with the key on
it won't run either. so far i don't have any money in this blazer, but don't want to waste money guessing.
Actually, 55psi should be enough fuel pressure on a '95, if yours has the same intake as my '96. I'm almost willing to bet that the problem is your starter. I know because I replaced mine recently, after eliminating all the other possibilities. Also, don't be surprised if you find you have to replace the battery too, since a bad starter can drain it.
What's funny is that my fuel pump then died two months later, so I had to replace it anyway.My pump actually had to dip below 46psi before it wasn't enough to start the engine.Good luck.
BouncingRadical
14
Nov 27, 2015 12:30 AM
koreiryuu
Feb 23, 2015 05:26 PM
jdmmario
Oct 25, 2014 06:25 PM
sullio
Sep 5, 2011 07:02 AM
mytruck2
Dec 13, 2006 04:50 PM
