still shifts bad from 1-2
Old Jan 7, 2011 | 02:49 PM
jsanders347's Avatar
jsanders347 is on a distinguished road
Default still shifts bad from 1-2
i had the tranny rebuilt about 40k miles ago. when shifting from 1st to 2nd its like it wants to shift but revs to almost 3k rpms and finally shifts. all other gears are fine. is this normal or is there a reaccuring issue? also i want to change the tranny fluid. ive heard lots of good things about royal purple. what would you guys reccomend?
Old Jan 7, 2011 | 03:18 PM
ChevyBlazerChick's Avatar
Did they put a Shift Kit in your Tranny?? My K5 has a Shift Kit and tends to shift hard into 2nd.
Old Jan 7, 2011 | 06:14 PM
Nah no shift kit. I've considered installing one with the fluid change. It lurches through 1st and I can't figure out why
Old Jan 7, 2011 | 06:37 PM
Hmmm, maybe someone with more knowledge can come around and give you some more info. Go ahead and post the specs of your Blazer, they will ask for it anyway, lol.
Old Jan 7, 2011 | 08:57 PM
TZFBird's Avatar
TZFBird is on a distinguished road
Sounds like a small leak in the 2nd gear apply circuit. You can check that by pulling the 2-4 servo out from the passenger's side of the transmission and checking seals. Otherwise, the 1-2 accumulator pistons are known to wear out in the pin bore and cause leaks that eventually lead to that problem. That has to be checked by dropping the valve body. A shop could do all that for you, or talk to people and see if anyone knows a kid going through automotive classes. I've actually learned some usefull tips from them time-to-time.
I'm not guranteeing my answer but that's $.02.
Lurching in first could also be caused by that same leak, or one in a different spot and the delayed 1-2 shift is a byproduct of it.
If you had your original transmission rebuilt they could have missed the issue, or you've put enough additional miles on it for it to show up.
Old Jan 8, 2011 | 02:14 AM
when they rebuilt my tranny they said something about a squirrel cage? and they showed my what the probem was and its hard to describe but it looked more like a big hamster wheel with some splines in the center and splines were all chewed up. is that anything your talking about or is that different? when it gave out i had no reverse and it when i went to shift to third it was like it hit neutral instead. i really appreciate your reply. very knowledgeable. thank you
Old Jan 8, 2011 | 02:18 AM
thanks for tryin. your responce is also greatly appreciated
Old Jan 8, 2011 | 03:50 AM
TZFBird's Avatar
You're talking about the sun shell. Those can break from time to time. If that is all they replaced, the problem I described could still be what's happening.
Old Jan 9, 2011 | 09:48 AM
If I were to attempt to do this myself how involved is it? This is my daily driver and would only have 2 days to spend on it. Would I be better of takin it to a shop? Would the failure of either part you described be means for another rebuild? Sorry for all the questions. Again, I really appreciate your knowledge and help.
DaveRush
Nov 5, 2011 06:30 AM
davtak
Jun 28, 2011 08:47 PM
Oneness_bc
Jun 12, 2008 09:29 PM
Hoelgi
Oct 11, 2007 02:37 PM
mikehillis1@yahoo.co
Engine & Internal
Dec 19, 2006 12:45 AM
