Stripped Crankshaft
Old Jul 17, 2020 | 04:08 PM
Americannoli's Avatar
Americannoli is on a distinguished road
Originally Posted by LesMyer
No RTV used. Mine isn't leaking, but a little tiny bit of RTV isn't going to hurt anything if done correctly. A lot of RTV inside your engine can slough off and end up going through your oiling system. If you put RTV on, put just a little thin smear in the balancer groove for the crank key and the part of the balancer that mates with the crank snout (not on the crank key or crankshaft itself). That way all RTV gets pushed to the outside of the engine when the balancer goes on. First spray down good with carb cleaner and dry good or RTV won't stick.
can you check and see how flush yours sits? This is as far as mine seems to be going? I think it might be spinning the crank.
Old Jul 17, 2020 | 06:26 PM
LesMyer's Avatar
Is this the Doorman balancer?
Old Jul 17, 2020 | 10:26 PM
Yea it is
Old Jul 17, 2020 | 11:03 PM
LesMyer's Avatar
I think it looks fine, but you won't really know until you put the bolt back in (should have way more than a few turns to tight) and the pulley/belt put back on. Make sure the crank pulley / belt lines up good with the P/S pump and you should be golden. You can run it for a little bit and then tighten the bolt again to be sure. Looks like good work if you now have a install tool threaded into the bolt hole!
Old Jul 17, 2020 | 11:18 PM
Yes! I sent a tap in there and removed the broken threads! Here's a picture of the water pump lined up what do you think?
Old Jul 18, 2020 | 08:27 AM
LesMyer's Avatar
Looks good to me!!
icb4uc
Jan 8, 2021 09:40 AM
Klturi421
Apr 27, 2012 02:58 PM
Wladziu
May 13, 2010 11:57 AM
sixgunzx2
Nov 30, 2009 02:38 PM
hubbmatt
May 16, 2009 09:09 PM
