stuck in first gear
Old Apr 21, 2008 | 07:36 PM
cagillman's Avatar
cagillman is an unknown quantity at this point
Default stuck in first gear
i got in my 85 k5 ( 350 with a 700r4 ,4" suspension and 33's)last week and started to head to the gym, then out of the drive i noticed the blazer would not shift out of 1st gear. i went back home and found the TV cable broke off from the carb. linkage. i reconnected the cable and i am still stuck in 1st. i have also checked the governor. is there anything else i can try before having a rebuild. if i have to have a rebuild i am wanting to put a th400 tranny in it. will a th400 bolt up or will i have to make modifications? thank you
Old Apr 22, 2008 | 10:57 PM
carpenter625's Avatar
carpenter625 is an unknown quantity at this point
Default RE: stuck in first gear
,did that on a 70 firebird and it was the vacuum line to the vacuum modulator on side of trans,if not that,check tranny fluid and see if it seems burnt or dark,there is a $6 botttle of solvent that u dump in there and run it thru all the gears and then change the fluid and pan gasket,worked in my 91 suburban for a long time
Old Apr 23, 2008 | 12:48 AM
Chevy Lover's Avatar
Check the TV cable to see if it's operating properly and adjusted correctly first.
If it came loose at the carb, it may be stretched or out of adjustment.
8five-k5
Nov 10, 2010 01:00 PM
77Nova
Aug 28, 2010 10:38 AM
hotrodsbyg
Jul 16, 2010 09:34 AM
gsmollin
Jan 30, 2010 03:53 PM
cide
Apr 3, 2009 03:28 PM
