Stumbling 94 blazer!
Old May 16, 2011 | 07:48 PM
Team Goofy's Avatar
Team Goofy is on a distinguished road
Default Stumbling 94 blazer!
I have a 94 blazer 4.3 cpi injection, truck has 60 p.s.i. fuel pressure when not started pressure starts to drop slowly within 5 min. is at 40 psi. when is running holds at 53 psi. which I know is slightly low. has good compression 150. each cylinder, fresh plugs ,wires , dist. cap & rotor button, new fuel filter. truck starts right up but when idle to 1/4 throttle stumbles bad then runs fine past that anybody have any suggestions before I change more un needed parts..............
Old May 16, 2011 | 08:47 PM
Leeann_Bravada's Avatar
Leeann_Bravada is an unknown quantity at this point
It has to hold above 50 psi for 10 minutes. You have a leak - either the FPR or the check valve in the pump.
Old May 17, 2011 | 07:10 PM
Team Goofy's Avatar
Thanx for your help......
jordanroch
Oct 6, 2013 09:13 PM
fenman00
Sep 26, 2013 09:34 PM
zstudna
Jan 23, 2013 07:41 AM
jester429
15
Nov 2, 2009 06:24 AM
Blazer4U
Aug 18, 2008 07:23 PM
