transmission cooling lines
Old May 15, 2011 | 08:06 PM
rseckinger's Avatar
rseckinger is on a distinguished road
Angry transmission cooling lines
I had a leak on the lower trnasmission cooling line at the tranny. I took the line out of the fitting...it was a quick disconnect....i was going to replace the o ring. I tried to get the line back into the fitting and now it wont go in. I can not figure out for the life of me why it wont go back in...Can someone help me or tell what i am doing wrong
2000 blazer
4wd, 4.3
Old May 16, 2011 | 06:53 AM
abig84's Avatar
could the oring you put on it be a little bit thicker then the old one, or is the old one still stuck inside there
Old May 16, 2011 | 07:28 AM
Z71_Guy's Avatar
Z71_Guy is on a distinguished road
i would have just replaced the fitting there cheep enough
Old May 17, 2011 | 05:36 AM
rseckinger's Avatar
i pulled the old o ring out and it still would not go back in without an o ring period. I would replace the fitting except the old fitting will not break loose for me to get out. It is as though someone put loc tite or the stupid thing is welded into the transmission.
Old May 17, 2011 | 07:29 PM
Z71_Guy's Avatar
well if you still cant get them in make sure the line end is not deformed in any way. and if its good keep trying it will go the line has to go perfectly straight in to the fitting.
mitchell27
Jan 30, 2013 12:16 PM
danyboy
Apr 11, 2010 08:23 AM
DillonO
May 15, 2009 10:17 AM
ejschultz
Apr 19, 2009 01:43 AM
mel
Jan 20, 2006 08:21 AM
