Sudden loss in oil pressure and squeal
Old Feb 13, 2012 | 09:08 AM
Adrienne3889's Avatar
Adrienne3889 is on a distinguished road
Exclamation Sudden loss in oil pressure and squeal
Need Help!
I have spent over $2,000 on my 1998 Chevy Blazer, in the past year, it has 160,000 miles. I neeeed desperatly to know whats up with it this time, it is my daily driver.
Driving down the interstate with cruise control set at 75mph, I had a sudden drop in oil pressure and could not accelerate. Pulled over cut the car off, tryed to crank it again it hesitated majorly, but crunk up slowly, with the check engine light now on, and a squeal...no smoke at all, just a squeal, so i shut it off tried it again, and same thin, crunk up slowly with a loud squeal. Called a tow truck. Could this be my oil pump, or have I blown the engine?
Old Feb 13, 2012 | 10:00 AM
pettyfog's Avatar
Originally Posted by Adrienne3889
Need Help!
Hope for the best. You obviously need someone to look closely at it. Best case would be the belt tore loose due to some driven bearing failure and ripped off the oil cooler lines.
However if you recently had intake gaskets replaced and had coolant in your oil.. probably bad news.
Old Feb 14, 2012 | 12:00 PM
chcknugget's Avatar
chcknugget is on a distinguished road
Doesn't sound good... Is the oil pressure still low? Metal in the oil? It might be new motor time.
matthewp
Jun 9, 2020 01:54 AM
2dr jimmy guy
Jan 26, 2013 09:36 PM
bryanmine
May 19, 2011 11:27 AM
ruralite85
Mar 31, 2011 08:17 PM
Ak95Blazer
Jan 7, 2009 06:56 AM
