Swap out delima
Old Aug 14, 2019 | 10:15 AM
Bud Wallace's Avatar
Bud Wallace is on a distinguished road
Default Swap out delima
I took a 2tad out and want to put in a 4kcd from a 2004 avalanche. Any problems?
Old Aug 14, 2019 | 10:18 AM
LesMyer's Avatar
I'm sorry but I have no idea what you are talking about.
Old Aug 14, 2019 | 10:22 AM
2002 blazer 4.3 4l60e 4x4. Will a 2004 avalanche 5.3 4l60e 4x4 transmission bolt in with no modifications?
Old Aug 14, 2019 | 10:39 AM
Cimmerian's Avatar
Are you asking if you can pull the same transmission your Blazer has off an Avalanche and fit it? Or are you talking about swapping the 4.3 for the 5.3?
Old Aug 14, 2019 | 10:48 AM
I want to put the transmission from the 5.3 avalanche into my 4.3 blazer.
Old Aug 14, 2019 | 11:36 AM
Cimmerian's Avatar
I'm pretty sure they are the exact same transmission. I'm sure someone with more intimate knowledge can confirm or deny.
Old Aug 14, 2019 | 11:44 AM
Apparently, the pilot in the 5.3 torque converter will not fit in the 4.3 crankshaft. I am finding out now that the swap out requires that I use my forward input drum, pump,and bell housing with my 288mm tourqe converter. Electronics are identical.
Old Aug 14, 2019 | 12:21 PM
LesMyer's Avatar
I would PM Transman304 and see if he will answer. He knows all this stuff and how to make it work if it can be done.
Old Aug 14, 2019 | 12:37 PM
Thanks for the advice my friend.
Dec 12, 2015 05:44 AM
Dechstang
Jan 4, 2014 10:12 PM
justkeepchuggin
May 18, 2013 09:54 AM
j89lumaye
Jan 31, 2012 09:57 PM
Tsa_Performance
Engine & Internal
Aug 3, 2006 12:59 PM
