Temp Gauge erratic after warmup
Old Jan 14, 2009 | 08:32 PM
tckocher's Avatar
tckocher is an unknown quantity at this point
Default RE: Temp Gauge erratic after warmup
From what I have observed. The level does not really change between cold and hot cycles. What does this mean? Also, if it is the gauge itself, how difficult/expensive would it be to replace? Thanks for the help guys.
Old Jan 15, 2009 | 08:12 AM
If the level does not change, it could be due to air in the system. Air compresses while water (coolant) does not. Air being in the system will compress as the coolant heats up and expands.
As far as the gauge sender, it is not difficult to replace, but you will need to drain the coolant level as the sensor is located in the side of the driver side cylinder head.
blkgagt
22
Jan 3, 2015 07:14 AM
filtalr
Sep 3, 2012 06:10 PM
zakm0n
Jan 9, 2011 07:31 PM
95fourpointthree
Feb 26, 2010 08:50 PM
mboehler
Jan 16, 2009 07:16 AM
