throttle body to CPI
Old Aug 11, 2015 | 08:27 PM
65Cents's Avatar
65Cents is on a distinguished road
Default throttle body to CPI
I bought a '91 S-10 with a bad 4.3. I have a good '93 4.3 with CPI, wiring and ECU, out of a Blazer I had. What do I need to do, to use it, with my 700r4 tranny, instead of the 4l60e tranny it had.
What about the fuel pump, do I need to change it also?
Thanks, Pat
Old Aug 12, 2015 | 07:55 AM
richphotos's Avatar
fuel pump would definitely need to be changed, and other things. I am sure others will chime in.
Old Aug 13, 2015 | 07:26 AM
65Cents's Avatar
Has anyone have an idea, as what has to be done, for the 700r4 to be used?
Old Aug 15, 2015 | 07:18 AM
chris015's Avatar
bolt it up,get a tv cable bracket from one that had a 700r4. wire up the tcc lockup switch to the brake pedal so when you touch the brakes the torque convertor unlocks.
yes,pump has to be changed.
prbjeepin
Apr 8, 2013 10:14 PM
shawn_dh
Engine & Internal
Jun 13, 2005 04:16 PM
blazernewbie
Apr 17, 2005 09:55 PM
02 Vortech
Engine & Internal
Mar 13, 2005 11:20 PM
94Blaze
Engine & Internal
Jan 5, 2005 09:59 PM
